Universal PCB for modules. (Arduino, etc )
A project log for NodeUSB- ‘Eat your own dog food’ WiFi IoT DevKit
NodeUSB is a tiny, low cost $9, WiFi ready, ESP8266 USB dev kit for Internet of things, it comes with NodeMCU pre-installed
michael-wenMichael Wen 04/21/2015 at 01:150 Comments
PCB have 8 headers (4 pins, 2.54mm). (With 6 different combinations )
So you connect different I2C modules (with different pin-outs) in just one Node. For example, you can use it to add both si7021 and bmp180 in your project. Sounds cool?
Also USB male and female pass-through, you can create Nodes Chain with several nodes!
