myPothole Detector
Identifies and logs potholes and their GPS coordinates directly to Google Earth!
Authorities across the UK currently pay out over £30 million in compensation every year due to poor road conditions. This means that it is in the authorities best interest to identify and fix potholes as soon as possible. myPothole Detector addresses the problem of quickly identifying and logging potholes meaning local authorities can fix these potholes as soon as possible.
myPothole Detector harnesses the power of the myRIO using the built in accelerometer which determines whether a pothole has been detected using the the z-axis acceleration and signal processing. A GPS module is connected to the myRIO via the serial port and logs the current location when a pothole is detected.
By connecting the myRIO to a PC with Google Earth installed, potholes can be plotted live onto the map. This makes it easier for the authorities to quickly see which areas are affected the most and can prioritise the fixing schedule based upon this.
Check out the project page for more info: Project Page
Now a bit of information about me. My name is Sean Fuller and I am currently on a one year internship at National Instruments. I study BEng (Hons) Electronic Engineering at the University of Portsmouth and this was my first project I created during my internship.
  • 1 × LabVIEW Software
  • 1 × Google Earth Software
  • 1 × NI myRIO Microcontroller and FPGA
  • 1 × 20 Channel EM-406A SiRF III Receiver with Antenna GPS Module
  • 1
    Step 1
    Steps to Implement or Execute Code Located on the Project Page
    1. Connect the myRIO to a PC via USB.
    2. Power the myRIO either by connecting the power supply that comes with the myRIO or using an external battery.
    3. On the PC, open 'Main.VI' found under the myRIO and make sure that you have the correct port selected. This will be dependent on what port you have used to connect the GPS module to.
    4. Run the 'Main.VI' which will automatically deploy to the myRIO.
    5. Run the 'Mission Control.VI' on the host computer.
    6. When the myRIO is ready to begin logging data, 'LED 0' on the myRIO will light. To begin logging, press 'Button 0' which will begin the acquisition. 'LED 0' will turn off when it starts.
    7. When the accelerometer detects a pothole, a marker will be placed on Google Earth and the position will also be logged in a data file stored on the myRIO.
View all instructions
rpkto57 wrote 12/07/2022 at 11:26 point
Repack has been known for the best business model in the case of logistics. It is a part of a big company named Traxion.  Redpack Rastreo is the prime company in Mexico which is famous for transport and logistics-related business, while Repack is mainly focused on the E-commerce side.
jtkng29 wrote 12/06/2022 at 16:54 point
jrs express Philippines is the go-to express delivery company for getting your purchased goods and merchandise from the merchant that is the person you are buying from and to your location or any address you would like the purchased goods or merchandise to be sent to.
