new revison rev2.3 - perhaps final revision
A project log for ESP8266 (ESP-07/12) Dev Board
PCB for fast development with ESP-07 / ESP-12 with on board USB to Serial converter and on board lipo charge / protection circuit
alexAlex 05/14/2016 at 21:280 Comments
This project is quite old now. And at least for me it is some kind of finished now. I do have have enough board for myself. At least if I do not give away to much boards boards in the future. And they are working fine. I did made some small changes after the last revision (rev2.2). I think the biggest issue was a wrong pin-mapping on the UART header. I decided now to publish the (maybe final) version including eagle files under CC BY-NC-SA. So you can now, if needed, make adjustments yourself. Please post some pictures if you do so.
Here are some renderings of the rev2.3 boards:
I will not order this revision for myself now. So if you use the files please consider that they are "untested". You can find the files in the bitbucket repository.
