ESP module layout rev 1
A project log for 200LX modules
Add-on modules for HP 200LX palmtop PC. USB-serial, WiFi, and maybe even more
zokierzokier 03/10/2018 at 22:320 Comments
Saturday well spent. Now I have all components in, nets routed, and passing DRC.
Still needs some tweaking. At minimum the silkscreen needs to be improved. But I'm generally pretty happy how this turned out so far, especially how everything mostly fit to the size I wanted even if it was completely arbitrary. I might even be able to shave a mm or two from the width.
