The claw is powered by an ACM604V60-01 motor and is welded to a 20 mm shaft. The central plate above is bolted onto the Z axis plate (left) and has pillow bearings for the claw and an attachment plate (above) welded on for the motor. The whole claw mechanism can be quickly removed and replaced with other devices to be designed and built in the future.
Hooray, this is what I wanted to know! Just wondering if you could improve the accuracy of the head to the point where you can try alternative weeding treatments. I'm thinking saline solution injection like for starfish eradication or laser burning the weed crown. Plenty of other esoteric options out there, I'm sure!
I use a weed prevention technique so weeds never appear in the first place. Accuracy will given by recognising the plants as a 2D grid with cameras.
