Status update
A project log for Foldable 50 W ultra-portable solar system for $150
comparatively low budget device for charging your camera/laptop/GPS/cell phone/sat phone/ham radio/flashlight batteries while backpacking
dylan-bleierDylan Bleier 04/28/2015 at 16:160 Comments
With $49 spent on the cells, I still need the following to finish the panel:
This should also be done for under about $150 total, since otherwise I might as well just buy a UniSolar 68 W panel which uses the same cells and ETFE coating, for under $200. However that panel only rolls up (does not fold) and probably weighs about 10 pounds alone. The purpose of the encapsulant film is to keep moisture out of the cells. The front and back films also help seal oxygen and moisture out.
Research on fluoropolymer front sheets (the most expensive sheet part AFAIK):
to complete the project, I also need:
