New ideas, starting now
A project log for Keep the basil alive
Automatic watering of basil plants
arminArmin 09/07/2015 at 20:010 Comments
OK some busy (non hacking) summer months have passed but I have not stopped this project.
Quick update:
So new ideas are: using the esp8266, Chirp sensor and a ds18b20 and start logging the data. For this I am using thingspeak My Channel for now I just have the temperature sensor. Later I will add the chirp and start measuring.
Also I am looking for a better way to pump the water. The container should still be a wine bottle. Just looking for a better way to pump water. It should make as little noise as possible. With the esp8266 it will also be possible to run it at night.
Also I have some ideas about scaling this up (see previous post). I am very pleased on how the hydroponics worked this summer. So the next month I will also research a bit more on running a hydroponics setup, indoors in the winter. So I will need some lights, logging of variables .....
So I will try to update this project a bit more the next few weeks.
