New tests
A project log for EMDrive/satellite
Developing a small fuelless microwave thruster
paul-kocylaPaul Kocyla 06/04/2016 at 08:043 Comments
Improved the floating platform by making the magnetic suspension weaker and made new#EMDrive tests:
This looks quite good. The tests with the cavity reversed show peaks in the opposite direction, but they are more narrow.
Files are in the repository (download the new viewer with bugfix).
Files: june01sr, june02br
RandyKC wrote 07/21/2016 at 20:11 point
Paul,
I wish you would create a separate project for the simulation effort so that others interested could like and follow this effort. I'd love to learn your approach to this. Maybe a Github project
I look forward to seeing how you would use OpenGL for this purpose. I've been looking at Modelica to see if I could do it there but the learning curve seemed steep and I couldn't sort out the basic open source capabilities from the commercial Add-on modules.
Paul Kocyla wrote 07/22/2016 at 06:01 point
The OpenGL will be just used for visualization of the paths. The main algorithm is planned to be like that: I´ll generate a discrete 3D-Space array and propagate the photons or waves within that. If photons take up the same cell in space but are 180° phase shifted AND hit a wall, they will not be reflected by the walls but just continue propagating.
I don´t know the result of this yet, will post results when finished.
Open sourcing: ok, but I am using my own toolchain now, have no time and effort to make the code clean and universal, maybe later.
[deleted]
Paul Kocyla wrote 06/12/2016 at 13:45 point
Suggestion denied. I suggest you to find another hobby than trolling. Thank you.
