tying up some loose ends before publishing the supporting dox
A project log for RaspiZero Motion Activated NOIR camera board
An RPi Zero-sized hat board with a Passive Infrared sensor, ambient light sensor and hi-power Infrared LED for lighting up a NOIR Camera
rogerarchibaldroger_archibald 02/17/2018 at 02:050 Comments
I'm currently waiting for some fresh IR LED's from Digi-Key to populate the final revision of this.  Once I give the schematic a final perusing and check to make sure I've flushed all of my usernames/passwords from example source code I'll post the rest of the supporting Docs.
