Checking the Printed Inset
A project log for 2001 Honda Odyssey AC Knob Repair
Using 3d printing to repair an AC knob for a 2001 Honda Odyssey.
shawn-gormanShawn Gorman 02/19/2018 at 01:220 Comments
Test fitting the print into the knob.  It was a tight fit. I sanded the edges a bit to get it to fit snugly, but there was a problem with the measurements that caused it to be off.
Here you can see there is a 1 mm gap on the flat side of the insert.
