Introduction
I am a high school student applying for the Repairs You Can Print Contest. Although I realize this isn't quite the kind of "repair" hackaday.io might be looking for, I thought it would make for an interesting submission.
As you may be able to tell in the picture below, Grey's right paw is significantly shorter than his left. He was born without his right one fully developing.
Although he can hobble around on his three legs pretty well, his owners are afraid that it will lead to premature hip and back problems. To combat this, we have been working on developing a prosthetic to make his legs of equal length. Luckily, one of the owners of Grey is a large animal veterinarian so he's available to provide some expertise on the issue; however, he's not used to working on this scale. I definitely would not have felt comfortable doing this project without an expert to consult when regarding the comfort and safety of the prosthetic.
Design Process
Taking measurements of Grey was pretty difficult. I used a combination of a tape measure, calipers, and a measuring tape. I usually relied on the circumference of limb which led to a few inaccuracies in the measurement. As I went about designing the part, I tried to keep it as modular as possible. The reason for this was so that the prosthetic could "grow" as Grey gets older and bigger. As you can see in the pictures below, he got pretty big in just a few months. Grey still had a functional elbow so I tried to allow for the use of that joint to make the walking motion more natural.
Prosthetic Pieces
Attached below are some of the pieces of the prosthetic:
Whole Assembly
Boot
This is the boot that Grey's paw slides into. As you can see in the wire frame image, it has a rounded cup for comfort and to help distribute the pressure from the base of Grey's paw. In addition, it has padding on the inside for added support. At the base of the boot you can see threads where the artificial "paw" screws into. I added the threads to ensure that the boot could accept various different printed paws. These paws would grow in size as Grey grows. In the future I was planning on designing different style paws for different ground textures (i.e. hardwood vs snow/ice).
Leg
As you can see on the top of this picture, the leg has threads that screw into the base of the boot. I included the cutouts in the middle to increase flexibility as well as eliminate weight. The piece is still very strong regardless of the cutouts and has a generous amount of flex. In the future, I plan to create a rugged texture on the bottom to increase traction on ice and snow.
Brace
This piece is the brace that holds the prosthetic onto Grey's leg. The slots in the side are for Velcro straps to slide in and wrap around the leg. The hexagonal extrusions on the sides are spots for the linkage pieces to attach. The reason they are so long is because Grey could only come in once every few weeks dew to scheduling conflicts so I made them larger to allow for more flexibility until we got the prosthetic to fit. On the edges of the extrusion are threads so that 3D printed screws can screw in and secure the linkage pieces.
Effectiveness
The prosthetic fit around Grey's paw very well and matched the length of his functional leg. The only downside is that the Velcro straps are not enough to keep it secured to his leg. Over the next few weeks I'm hoping to work with the veterinarian involved in the project to pursue some other methods of attachment. I'll be sure to keep the hackaday.io community updated!
Benefits of 3D Printing
3D printing was the obvious choice for this project due to the customization of the prosthetic. Usually veterinarians will not make a prosthetic for a dog until they are mostly done growing because the procedure is costly and difficult. Through a combination of Fusion360 and 3D printing, I was able to change my design and print a replacement within a matter of hours, sometimes minutes. Also, 3D printing the pieces kept costs fairly low for the project.
Challenges
Having no experience in the realm of prosthetic design, I faced plenty of challenges throughout this project. I really had no good method to measure Grey's limbs. My measurements were often rough estimates due to Grey's hair. In addition to that, Grey grew to nearly three times his initial size over the course of the project. Ultimately, I feel that the product turned out quite well when taking the tools that were available into account.
Additional Pictures
