Blinking Cursor
A project log for ChassC
As in 'Chassis for C' Simple Direct Media Layer (SDL2) Template for C++
morningstarMorning.Star 02/19/2018 at 08:030 Comments
One of the reasons I like Python is Pygame, coincidentally written in SDL. It allows me to open up a graphics window, instead of boring console based stuff. I love the terminal, but sometimes a mouse is the only way. Doing that in C++ used to be a nightmare before I learned SDL. Interfacing to X directly is densly documented, I'm digging into that but its pretty much Linux-only research.
This should work on anything...
First of all, you'll need a working compiler.
sudo apt-get install g++
GNU C++11. I dream in this sometimes, recommended. ;-)
Next you'll need a copy of the SDL Library and at least the SDL_Image library, with development files.
apt-cache search libsdl
libsdl2-2.0-0 - Simple DirectMedia Layer
libsdl2-dbg - Simple DirectMedia Layer debug files
libsdl2-dev - Simple DirectMedia Layer development files
libsdl2-doc - Reference manual for libsdl2
libsdl2-image-2.0-0 - Image loading library for Simple DirectMedia Layer 2, libraries
libsdl2-image-dbg - Image loading library for Simple DirectMedia Layer 2, debugging symbols
libsdl2-image-dev - Image loading library for Simple DirectMedia Layer 2, development files
libsdl2-mixer-2.0-0 - Mixer library for Simple DirectMedia Layer 2, libraries
libsdl2-mixer-dbg - Mixer library for Simple DirectMedia Layer 2, debugging
libsdl2-mixer-dev - Mixer library for Simple DirectMedia Layer 2, development files
libsdl-ttf2.0-0 - TrueType Font library for Simple DirectMedia Layer 1.2, libraries
libsdl-ttf2.0-dev - TrueType Font library for Simple DirectMedia Layer 1.2, development files
You'll need at least
sudo apt-get install libsdl2-2.0-0 libsdl2-dbg libsdl2-dev libsdl2-doc
and
sudo apt-get install libsdl2-image-2.0-0 libsdl2-image-dbg libsdl2-image-dev
to get a minimal working installation.
Now for the fun part.
C++ doesnt have many prerequisites to just jump in, there are a few tho. CIN, COUT and the SDL library, plus tell the compiler I'm too std::lazy to type classes, I'm not using them.
#include <iostream>
#include <SDL2/SDL.h>
using namespace std;
 Some basic parameters and somewhere to put stuff and we're off.
#define W 1024
#define H 768
SDL_Window * outputwindow = NULL;
SDL_Renderer * render = NULL;
outputwindow * stores the structure to the window instance, feeds user input back to the program and hosts the renderer.
render * stores the actual display, it is this you'll be writing to.
int main() {
  outputwindow = SDL_CreateWindow("ChassC", SDL_WINDOWPOS_UNDEFINED, SDL_WINDOWPOS_UNDEFINED, W, H, 0);
  render = SDL_CreateRenderer(outputwindow, -1, SDL_RENDERER_ACCELERATED);
  SDL_Delay(3000);
  SDL_DestroyWindow(outputwindow);
  SDL_Quit();
There are other options to opening a window, it can be borderless and fill the display, plus SDL handles multiple displays nicely, and can jump a window from one display to another easily.
Running that code will briefly open a graphical window before exiting gracefully.
