Battery node
A project log for Home security
Home security project based on atmega and ardunio. MQTT gateway for data gathering.
vysocan76vysocan76 02/12/2016 at 09:150 Comments
New node boards have arrived. I've ordered first time from seeed, and they look quite good. Nice sharp traces, I use usually bigger ones, as I tend to hand solder sometimes. Nicely aligned solder mask, and silkscreen without smudges. I will use them in future for sure. This board was also for me first board to be made in KiCad, instead of Eagle, as I needed bigger PCB area for new gateway(main board). I can just say all as expected, if you check your Gerbers, there should not be any surprise. I feel a bit more confident to spend $50 for the big boards.
More on blog...
