Barrel Roll
Arduino Micro rain barrel timer pump
I had need to distribute water from my rain barrel to the garden in regular intervals. Gravity feed wasn't working, manual start was lame, and frequently I would forget to charge the battery thus... I built an solar powered Arduino based timer pump.
Step one: Purchase a proper barrel
In Austin, the city provides per gallon rebates on rain barrels which I find compelling. I wanted a large barrel, but with dimensions based on annual rainfall and reason. The end result is a 150 gallon barrel based on the dimensions of a guttered section of my roof. The math goes something like this: Approx 300 square feet of roof area, or 43200 square inches yields 189 gallons of water with a storm providing 1 inch of rain. This seemed reasonable given the Flood Early Warning system rain gauge reports provided by the city, http://www.ci.austin.tx.us/fews/rainfall.cfm.
Step two: Calculate interval
I don't have a real interesting calculation for this, every two weeks or so I wanted to empty the barrel if no rain was present. Final distribution settings are 5 mins at 5 gallons per minute every 3 days, ~18 days of watering with no refills.
Step three: Dig a trench
I have existing conventional irrigation in the backyard, so I carefully dug a 60 foot trench to my back garden with a pickaxe, about 6 inches deep. Next I laid some PVC with a few access points into the trench. At one end of the pipeline is a two foot high bush sprinkler, the other has a quick connect buried underneath the ground, but accessible via a plastic in ground porthole.
Step four: Buy the kit
This step was basically get on Amazon and find components that fit my needs, mentioned below. I often use the SLA batteries or banks of them combined with Instapark charge controllers and panels in projects around the house. Cheap and decent. All of my power tools, including my mower, are charged using similar solar configurations.
Step five: Build!
  • 1 × Wayne DC Garden Pump 12V 15ish amps, 5 GPM
  • 1 × Arduino Micro Simple USB powered board for toggling the relay board
  • 1 × Arduino Relay Board Triggerable by the Arduino Micro, and capable of switching the high pump amperage relay
  • 1 × Automotive Relay Enabled by the Arduino Relay Board, does the heavy lifting of switching 15+ amps
  • 1 × 12V 7ah SLA battery The battery
View all 7 components
View all 3 instructions
nodemcu12ecanada wrote 05/28/2020 at 18:23 point
Control/monitor your system on WiFi using NodeMCU.
https://sites.google.com/site/nodemcu12e/
