Well, that went poorly
A project log for Crazy Clock
A replacement controller for Lavet stepper clock movements
nick-sayerNick Sayer 12/03/2016 at 03:440 Comments
The first prototype boards came back with the new layout for the TLV61225 boost converter.
With a bench supply, the old NCP1402 based boards took 30 µA. Under the same circumstances, the TLV61225 based board takes 80 µA. That's no good.
The good news is that the TPS61221 is pin-compatible with the TLV61225, so I'll give that a try. I'll be satisfied if the draw is under 50 µA even if it's not quite all the way down to 30 µA.
