hard bit of code
A project log for Smart Home controllers
Making a Smart Home controller. Stations for each room will a master controller for the home
john-jensenjohn jensen 05/27/2015 at 04:450 Comments
seems its a bit harder to work in the small space of the 328p than i thought. I need to push alot more to the EPROM than I thought. I am going to try re-skinning the refresh area's of the program by storing it in the EPROM, which makes skinning the interface harder.
I need 10k bytes for code and some leftovers for ram. Its proving to be a challenge.
new additions:
hot water heater control ( it runs all day but is only needed at certain times so, why not control that?)
and for the main board water irrigation system ( this was asked but not sure if needed quite yet)
