Arduino managed electronic front & rear derailleur
A servo driven DIY electronic derailleur, now for both front and rear.
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
A servo driven DIY electronic derailleur, now for both front and rear, based on Arduino . The code is now complete, and fully tested on the bench mock-up, and ready for a road test. If you lose your chain and lose track of where you were, a button resets so you can place the chain where it should be, as shown on display, and go from there, or do a complete reset to defaults.
Code for Arduino, and construction detail for this project is available at www.excelworks.info
