Google Home Version /w TTS
A project log for Washing Machine IoT
This is a non-invasive WiFi Washing Machine Monitor
profitpRoFiT 03/10/2021 at 04:560 Comments
Okay so i found someones code on how to send tts to google homes. after some major modifications and copy paste from my old code i have it working.
Here is the github location i borrowed it from https://github.com/debsahu/GoogleSay
his was cool and overkill for what i needed. Maybe
//https://github.com/horihiro/esp8266-google-home-notifier
 was all i really needed to look at.
Now when the wash completes it will tell me on my google mini
I think i will add a loop where it keeps telling me once a minute until i open the wash door and the light goes off. Otherwise i may miss the notification
#include <ESP8266WiFi.h>
#include <WiFiClient.h>
#include   //https://github.com/horihiro/esp8266-google-home-notifier
//https://github.com/horihiro/esp8266-google-tts
const char* ssid     = "SSID";
const char* password = "PASSWORD";
const char GoogleHomeName[] = "NAME OF GOOGLE HOME DEVICE";  //Must match the name on Google Home APP
// analog portion
int add1=0;
int add2=5;
int add3=2;
int an=A0;
const int triggerLevel =  200; // level to trigger change in ledstate
int sendWashComplete = 0; // set 0 at start, 1 when trigger is hit, 2 once sent, back to 0 during if start has started or all leds off like when wash is done and lid is opened.
int sendWashStart = 0; // set 0 at start, 1 when trigger is hit, 2 once sent, back to 0 during if complete or all leds off
int ledStates = 0; // use bitwise for keeping track. one number to compare against
int lastLedState = 0; // set same at start. only check once they change in a loop.
GoogleHomeNotifier ghn;
void connectToGH(){
  Serial.println("connecting to Google Home...");
  if (ghn.device(GoogleHomeName, "en") != true) {
    Serial.println(ghn.getLastError());
    return;
  Serial.print("found Google Home(");
  Serial.print(ghn.getIPAddress());
  Serial.print(":");
  Serial.print(ghn.getPort());
  Serial.println(")");
String ipToString(IPAddress ip){
  String s="http:// ";
  for (int i=0; i<4; i++)
    s += i  ? " dot " + String(ip[i]) : String(ip[i]);
  return s;
void setup(void) {
  Serial.begin(115200);
  Serial.println("trying to connect...");
  WiFi.mode(WIFI_STA);
  WiFi.begin(ssid,password);
  while (WiFi.status() != WL_CONNECTED) {
    delay(500);
    Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected");
  Serial.println("IP address: ");
  Serial.println(WiFi.localIP());
  connectToGH();
  String init_text = "Washing Machine Application has started";
  if (ghn.notify(init_text.c_str()) != true) {
    return;
  Serial.println("Done.");
  pinMode(add1,OUTPUT); //analog control
  pinMode(add2,OUTPUT);
  pinMode(add3,OUTPUT);
void loop(void)
  byte i;
  for( i=0;i<=5;i++)
    setAddress(i); // switch analog port before reading
    delay(50); // give 50ms to let analog switch complete.
    bitWrite(ledStates, i, 0); // set 0 before loop
    for(int x=0;x<1500;x++) // comes out to about 1 second scan rate for all 6 leds with given switch delays etc...
      if(analogRead(an)>triggerLevel) // read level output and compare
        bitWrite(ledStates, i, 1); // if we see it go high after anytime during the 1500 loops, set high or LED ON STATE. This should eliminate 50/60hz led issues on the wshing machine...ugh....pain.
  Serial.println(ledStates); // simpler i guess
  if(ledStates!=lastLedState) // if there was a change from last loop do something
    switch(ledStates)
      case 16 : // wash complete state [0,1,0,0,0,0] = 16
        if(sendWashComplete == 0)
          sendWashComplete = 1; // 1 means we need to send notification.
          sendWashStart = 0; // 0 means it can be triggered again
      break;
      case 33 : // 33 is start and locked. sometimes both are on at same time.
        if(sendWashStart == 0)
          sendWashStart = 1; // 1 means we need to send notification.
          sendWashComplete = 0; // 0 means it can be triggered again
      break;
      case 1 : // 1 is start only
      break;
      case 0 : // clear notifications if all leds are off machine is off or completed and lid opened.
      break;
      default : {}
  if(sendWashComplete == 1) washComplete();
  if(sendWashStart == 1) washStart();
  lastLedState = ledStates; // at end of loop so we can test next loop
void washComplete()
  Serial.println("Wash Complete");
 String init_text = "The wash has finished";
    return;
void washStart()
  Serial.println("Wash Started");
 String init_text = "The wash is starting";
    return;
* setAddress(byte i)
* Take byte value and output the bits, 3 bit address
void setAddress(byte i)
  if(i & B00000001) digitalWrite(add1,HIGH);
  else  digitalWrite(add1,LOW);
  if(i & B00000010) digitalWrite(add2,HIGH);
  else  digitalWrite(add2,LOW);
  if(i & B00000100) digitalWrite(add3,HIGH);
  else  digitalWrite(add3,LOW);
