A separated programmer - Thu Jun 25 22:20:20 UTC 2015
A project log for IOTsatcom is IOT and robotics everywhere
Global two-way satellite communication for robotics and IOT sensors. Easy to use, GPIOs, telemetry, low power and web API provided.
fabio-balzanoFabio Balzano 06/25/2015 at 22:320 Comments
I want to propose you the idea of a separate programmer for the Freescale CPU, I designed the above block following the schematic of Teensy 3.1 at the pjrc.com website. I divided the Teensy 3.1 in 2 blocks, programmer and CPU.
Possible benefits:
Let me know if this idea could be interesting for you and you think this is a necessary feature for the project.
Thank you.
