Simplified Monadic Gates 7 And F
A project log for Tern - Ternary Logic Circuits
A series of ternary logic gates and higher level components implemented in the real world.
mechanical-advantageMechanical Advantage 08/29/2015 at 07:460 Comments
The use of Wired AND has allowed me to simplify the two most complex monadic gates. Previously, the gates 7 (0 + -) and F(- + 0) were the only monadic gates that required three comparators so that they could not be built with a single LM319. With this change all monadic gates require only one 319 at the most.
The updated schematics are here and here.
