Fun With Diode Logic
A project log for Tern - Ternary Logic Circuits
A series of ternary logic gates and higher level components implemented in the real world.
mechanical-advantageMechanical Advantage 02/20/2016 at 08:240 Comments
I have started using pull-middle resistors here and there where appropriate and realized I hadn't ever tried these in combination with two-input diode gates. I already make common use of forward biased diodes with a pull-down to make a Max Gate and reversed biased diodes with a pull-up to make a Min Gate. Using forward biased diodes with a pull-middle gives this truth table:
Forward Biased, Pull 0
B
0
A
0
0
0
0
0
Using reverse biased diodes with a pull-middle gives this truth table:
Reverse Biased, Pull 0
B
0
A
0
0
0
0
0
Neither is of particular importance, but it's nice to keep that in my bag of tricks. The more gates I can make with fewer components the better. Sorry for the messy tables but not a lot of formatting options are available.
