Protect your Arduino!
A project log for CAN BUS Gaming Simulator
Controlling a VW CAN BUS dashboard of a Polo 6R with an Arduino and a CAN BUS shield using the Telemetry API of Euro Truck Simulator 2
leon-batailleLeon Bataille 11/15/2015 at 15:410 Comments
Please make sure, that the diode on the Arduino UNO doesn't get too hot. If you use a Chinese clone Arduino you should be even more careful as those models get even more hot.
I recommend to connect the dashboard pins 31 and 32 with an external 12V DC power supply!
