The Big Red Button
A project log for PiBooth
RaspberryPi photo booth to help capture memories at your events.
john-leemanJohn Leeman 07/30/2015 at 13:240 Comments
A few photos of putting "the big red button" that starts the photo taking process in a diamond plate case from Hobby Lobby. I used antenna rotor wire for the cable and a 3 pin connector from Amazon. The connector is a little hard to connect/disconnect, but hopefully it wears it well. The button has an LED in it (hence the three wire cable), but I was totally underwhelmed by it's brightness and coverage, so I opted to not connect it for the time being. Don't forget a grommet to prevent wire damage from the metal box!
