G160 Casing and Nozzle
A project log for High Power Experimental Rocket Platform
Experimental high power rocket with active stabilization, live telemetry, autonomous GPS guided recovery and HD video
j-m-hopkinsJ. M. Hopkins 06/26/2015 at 02:330 Comments
This motor has a 9" case, 4x1.75" Bates grains at 3/8" bore and a nozzle diameter of 23/64".
The nozzle has two fender washers as the choke to prevent erosion and uses anchoring cement for the nozzle itself.
Overall pressure should be 300 psi and average thrust of 36lbs, and total impulse of 132 NSecs.
