Frames of Divergent Nozzle Failure
A project log for High Power Experimental Rocket Platform
Experimental high power rocket with active stabilization, live telemetry, autonomous GPS guided recovery and HD video
j-m-hopkinsJ. M. Hopkins 07/06/2015 at 22:080 Comments
The first image is soon after full pressurization, showing excellent flow from the nozzle.
The second photo shows a concussion as the divergent section of the nozzle blows out.
After the nozzle blows out, you can see the jet under expanded.
It is obvious after this third test of my H268 case and nozzle that modification is needed.
