H Class - 11" Casing Static Test
A project log for High Power Experimental Rocket Platform
Experimental high power rocket with active stabilization, live telemetry, autonomous GPS guided recovery and HD video
j-m-hopkinsJ. M. Hopkins 07/19/2015 at 19:080 Comments
Testing of an 11" Casing, 1/2" Bore, 3/8" Nozzle. Complete Success.
Ignition time was longer than anticipated and might need adaptation for a faster complete bore ignition.
In the slow motion portion of the video you can see that the igniter appears to be partially inhibiting bore ignition and when enough pressure builds up the igniter ejects and complete bore ignition occurs.
