Static Test 012 - 12.5" Casing
A project log for High Power Experimental Rocket Platform
Experimental high power rocket with active stabilization, live telemetry, autonomous GPS guided recovery and HD video
j-m-hopkinsJ. M. Hopkins 07/21/2015 at 02:520 Comments
ST012 - 1D/11C/.5B/.375N/300P
Another successful static test. With this log post I will create a standard naming scheme for static motor tests. Logs will start with ST and ends with an auto increment numerical value. After will follow case diameter, bore size, nozzle choke width, and propellant batch size.
Sorry for the video orientation, I was trying to capture as much exhaust as possible
