Launch Date and Fuel Grains
A project log for High Power Experimental Rocket Platform
Experimental high power rocket with active stabilization, live telemetry, autonomous GPS guided recovery and HD video
j-m-hopkinsJ. M. Hopkins 11/12/2015 at 17:190 Comments
If the weather holds true the first launch of my rocket will be on 21 November at the MDRA launch in Maryland. It will test numerous things:
To limit ejection failure I'll be utilizing a secondary altimeter.
I'll be testing a few new motor concepts (progressive single grain, BATES grain, and finocyl grains) and deciding which motor I want to fly with after a few static tests.
Here's the sample of the fuel grains that are going to be in a BATES configuration:
And the cast nozzles waiting to be used.
