Ignition Testing
A project log for High Power Experimental Rocket Platform
Experimental high power rocket with active stabilization, live telemetry, autonomous GPS guided recovery and HD video
j-m-hopkinsJ. M. Hopkins 01/19/2016 at 02:310 Comments
One of the issues I've dealt with most of my motor testing was a relatively slow ignition time. This was caused by the necessary build up in pressure before enough hot gass propagated through the case and the motor achieved full ignition.
To enable faster ignition I needed both an ignition source and pressure source. To that end I've built a new igniter:
It successfully gives me that instant on ignition that had been eluding me.
Here's an example of an old finocyl bored grain being ignited with the previous method:
