First of all, I want to excuse myself for my very bad English.
This project consists in a set of instruments build around energy needs and self independence. In fact, it may affect every body in the world, because, this system combines automobiles and (small) home/office needs of electric power.
The system consists in a completely new CAR battery, based on a Graphene bank of caps a control system and a Li-Po pack, and on a modified UPS, and some solar panels.
This system have two main instruments, one is the new car battery itself, and the second is a UPS that can be charged for almost every way and every were, starting for direct car charging connected direct to the appropriate car battery out port, and, can be charged with a solar panel (provided), wind generator or even a mobile phone charger!!! Everything more than 3V charges this system!!!
The UPS system provides every power level needs, from mobile phone charging 5V, to a 12V output, and 220V, that can be used simultaneous.
The idea is to recharge it from solar, wind or during the car travel, than, when you arrive to your destiny you have a full UPS for hours of work.
The new car battery was designed because the fast charge/discharge proprieties of the Graphene caps, and because of weight. The UPS have a small Graphene caps bank too.
