[Matt]'s request: Italics, centered, under picture
A project log for Hack the Hack A Day Editor
A hack based on "HTML Injection". Useful when you want an online editing feature that is not available otherwise. Might work on any Website.
rogeorgeRoGeorge 07/04/2015 at 07:531 Comment
<DIV align="center"><I>LED turned on full brightness. You can see I get about 5v ripple current. Ouch.</I></DIV>
Well, it seems like it doesn't worked
:o)
Let's try harder:
Yeee, it's working! Italics and centered!
Back to normal
How it was done
Use Chrome Version 43.0.2357.130 m. It should work with other browsers too, but I didn't test them.
Note: If you continue editing the Hack A Day page after you made a HTML code injection, the next paragraph will keep the modified format, so you need to apply the same technique to come back to normal.
Nolan Moore wrote 04/27/2016 at 01:06 point
Verified to work in Firefox as of version 45.0.2!
