Vivado first test
07/30/2015 at 19:36 • 0 commentsAt least all supplies are OK, JTAG of course also!
PCB ORDERED!
07/15/2015 at 09:59 • 0 commentsFinally the PCBs are ordered one panel, we will get total 24 Board for the first run. Should arrive 22 July.
PCB finalized
07/07/2015 at 16:36 • 0 commentsBT LE is off the board, replaced with 8 pin socket for ESP2866 WiFi module. Ready for production!
BT LE changed to connector for WiFI
07/06/2015 at 11:20 • 0 commentsLast minute change the BT LE IC is going off the board, and will be replaced with 8 pin socket ready for the ESP8266 module.
