HW & SW update & upgrade
A project log for Yet another home automation project
This home automation project is almost nothing special compared to other projects and in intended to just give new ideas to people like me.
avamanderAvamander 07/30/2015 at 09:560 Comments
Received perfboards and started moving nodes from breadboard to a perfboard. Never done this before, takes huge amount of time. I also discovered that the automatic temperature regulation does not work on my iron so I can solder only a certain time before it goes insanely hot.
I also tided up the code. It's a bit more stable.
