Boards
A project log for GPS Disciplined xCXO
A DIY GPS disciplined 10 MHz reference clock
nick-sayerNick Sayer 07/25/2015 at 15:580 Comments
I've shared the board design over at OSHPark. Some details not obvious from the schematic:
I'm probably going to order the first set of boards today, but I want to make sure the D/A chips fit in the layout before I commit. They're the last untested footprint. I'm also probably going to try and breadboard one and feed it with a basic sawtooth sketch (a tight loop that writes a continuously incrementing value to the D/A) to test it.
The OSHPark shared board used to be linked here, but that board isn't going to work - the 3.3V regulator will overheat badly. I'll link to the final board once it's tested (in about a week and a half).
