Another way to look at it
A project log for GPS Disciplined xCXO
A DIY GPS disciplined 10 MHz reference clock
nick-sayerNick Sayer 11/06/2015 at 15:450 Comments
Here's another way to look at the DOT050V based GPSDO: Time deviation.
This graph shows the deviation (relative to an OH300 based GPSDO) in time of one of the DOT050V based GPSDOs I've built.
What this graph effectively means is that if you built a clock from both of them, the two clocks would be within 70 ns of each other after 1000 seconds, and would stay that way at least out to ~15000 seconds.
