Easy inspecting with a stickvise
A project log for Full Metal Stickvise
Made my own Stickvise from some pieces of brass and aluminium I found in the cheap scraps at the local metal supplier, and some stock I had.
martijnMartijn 05/21/2018 at 22:080 Comments
I was trying to repair my AVR Dragon
I think my reset line is fried, and the given solution for this seems to be replacing two IC's. Sadly 2 pads came off along with one of the IC's and I tried to fix it with some tiny wires. But the parts on the dragon are rather small and i was afraid I might short some pads, so I looked for a way to do some inspecting.
My magnifying lamp isn't ideal for that, but I'd just received the magnifier I bought from a chinese webstore (tbh, I didn't buy it with electronics in mind). And this was just too easy to do:
If I had known I was going to do this, I might have looked a bit better at the optimal magnification and focal lengths and such.
The dragon didn't make it (yet), my last replacement IC sprung from my tweezers and disappeared in a puff of smoke. (I have an Atmel ICE now, which is nice and fast, but has a stupid 1.27 mm grid connector)
