Got my Lattice iCEstick (1K) and iCE40-HX8K Breakout Board dev boards today from mouser, and have also had a quick go at compiling iCEStorm (http://www.clifford.at/icestorm/) on my mac.
OS X (Yosemite) Instructions
Need Brew package manager to get the various GNU packages that OS X doesn't come with. Commands I fired off were
brew install gawk
brew install pkg-config
brew install libffi
brew install readline
brew install bison
brew install gnu-sed
brew install hg
brew install libftdi
For IceTools, you will need to change icebox/Makefile from using python2 to python before it will build the DB files required.
Download both yosys and arachne-pnr and compile with make
iceprog make file needed hacking to find ftdi header and library path.
It all compiles, haven't actually tried it, yet but should be no problems as far as I can see now :)
would you mind sharing the changes you made to the makefile?
