Actuator Module Progressing
A project log for VentController
An IoT-enabled system for automated environmental control.
steve-morganSteve Morgan 08/13/2015 at 20:540 Comments
Having got the sensor module working, I shifted my attention to the Actuator module. This is built on an identical board to the Sensor Module, but has the following connectors instead of the I2C bus connectors:
At the moment, I only have the relay board connected. I've updated the Actuator sketch to control the relays, operating the vent motors. One issue that I currently have is that there's no feedback loop for me to know the actual vent position. Instead, the Actuator module forces the vents closed when it boots, thus giving me a 'known state'. The original vent controller didn't do this, which was a problem if it had to be restarted or the power failed. It's also responding to commands over MQTT to set the vent position. This is how the system will ultimately function; an external cloud-based service will determine the desired vent position from the sensor data and send a message to the Actuator Module over MQTT to establish that position. At the moment, my test service sends random position commands to the module, so it's sitting here clicking relays on and off on an irregular basis.
