LPS
A project log for LPS Mini
Arduino compatible indoor navigation system with small form factor.
gran-nordahlGöran Nordahl 08/15/2015 at 16:452 Comments
After some thought the project name RadioBeacon was dumped for Local Positioning System - LPS. Lessons learned with RadioBeacon v1.0 was implemented in LPS v1.1:
The updated schematic, assembly drawing and BOM:
http://www.loligo.se/navigation/LPS_v1.1_150409.pdf
PCB animation:
http://www.loligo.se/navigation/LPS_v1.1.WMV
Göran Nordahl wrote 07/28/2016 at 13:22 point
In this case it the GND plane is on plane 2 out of 4. There are many things affecting the performance. If you are having problems with your own design it can as well be due to decoupling, layout etc.
leandro wrote 07/28/2016 at 13:18 point
Hi.
First, sorry for my english.
About this topic: "Need for a slightly wider PCB to get better antenna performance."
This perfomance gain is result of increasing GND layer in PCB bottom?
Thank you.
