kicad_pcb export
A project log for MeowCAD
An online free and open source electronic design tool that runs in your browser. See it live at https://meowcad.com
abetuskabetusk 08/28/2015 at 22:020 Comments
Very experimental "kicad_pcb" export is now available. kicad_pcb is the "new" KiCAD export format. The previous iteration (the one with a ".brd" extension) is being deprecated in lieu of the "kicad_pcb" format.
The "kicad_pcb" format is in something called "s-expression". The conversion tool created was one that goes from MeowCAD's internal JSON format to the "s-expression" format that the "kicad_pcb" files use.
You can see the new code on my GitHub page, specifically the json2kicad_pcb.py that does the conversion.
I've successfully exported the 'h8ARt' project. Here's a screenshot:
It's probably got a lot of issues but it's a start.
