Shafts are now ready. Splitting the shaft from 500mm to two 240mm. Grind top and bottom and bearings fits like a glove.
Test assembly with 3D printed motor brackets and wheel hub. Everything fits perfect! I will add some extra mountings for the the vertical support beam. Other then that I think they are ready for CNC milling.
The horizontal support beam fresh from the CNC.
Check out posts on the the build blog valify.se/2018/03/16/3d-printing-prototype-motor-brackets/
