Tonight I have begun building the robot's URDF for better and nicer visualization in RVIZ when driving around. I also hooked up the 9DOF to test and confirm its functionally .I am using the (SparkFun 9DoF Razor IMU M0 - SEN-14001) and it was not easy to get it to work over ROS, but finally it did The URDF will be an exact copy of the real robot and I will mostly use combined STL´S files as meshes for the URDF. |
