Updated Hip Linkages
A project log for Tension Biped - A new take on a 9g Servo Walker
- A new take on a 9g Servo Biped Walker
hooptie-jHooptie J 08/19/2015 at 18:092 Comments
Continuing basic range-of-motion checks, i noticed that the linkages for the hips would hang up on the hip mounts, did a minor redesign- it got rainy and humid here yesterday, so my 3D printer got really finicky- it only took 3-4 tries to get the linkages printed, but finally, success.
New Hip Linkage - Slimmed for clearance.
And installed on Mk3.
deʃhipu wrote 08/27/2015 at 11:22 point
I wonder, have you considering using nylon or acrylic bolts, instead of metal ones? I recently replaced the metal bolts with acrylic in one of my robots, and it's so much lighter! And lighter means less force needed to move it and less inertia.
Hooptie J wrote 08/30/2015 at 09:16 point
One of my aims was to use only stuff i had in my "Project pile" already - so my source for "hardware" has been the random coffee can on my workbench.
I'd consider nylon hardware for some of the parts, like the front bulkhead there, but i probably wouldnt use it on those hip linkages- after actually power it up and testing, i managed to warp and crack a servo horn there, not sure if plastic hardware would be the best plan.
My first investment however is more likely to be in an Arduino micro/mini, a battery & some 2.4ghz transceivers so i can eliminate the tether.
after adding battery weight, i may very well be revisiting the "heavy hardware" question though.
