Arduino Automotive Shift Light + Tachometer
Arduino + WS2812 LED Shift Light
Built around the 328P, this customizable shift-light is an inexpensive alternative to professional models that cost hundreds more. New features added in V2 mean you don't have to mess w/ the code at all - just upload it to your Arduino Uno.
Here's a list of the adjustable settings: brightness, activation rpm, shift rpm, hardware or software RPM frequency sensing, signal conditioning, engine size calibration, number of LEDs, segmentation and colors of the LEDs, EEPROM memory, +10,000 RPM readout,
supraisthebest428 wrote 07/04/2022 at 19:39 point
can you provide the programming code
yuyang wrote 03/10/2024 at 13:22 point
https://github.com/chippernut/ShiftLightV2_1/
k.bennett744 wrote 08/09/2017 at 10:14 point
Works great until you try to pick up the RPM signal from the coil then it is very susceptible to noise even with screened cable and ferrite coil
