Keypad
Adding a 12 key keypad (0 to 9 with * and #) requires seven i/o pins. Each switch connects one row wire to one column wire. Connection scheme used in the test code is shown below. 300 ohm resistors protect the outputs from short circuits when multiple switches are closed. The 10K pulldown resistors provide an input source when the switches are open. The code displays the button label when a button is pressed, and -1 when no button is pressed. If you add one line of code, you can eliminate the three 10k pulldown resistors by turning on internal pulldowns. The poorly documented CNPDB register (Change Notice Pull-down Enable B) selects input bits to pull down. Setting <br>CNPDB = BIT_7 | BIT_8 | BIT_9
in the keypad thread pulls down B7, B8, and B9. To be safe, you should probably clear the CNPUB register to turn off pull up resistors.
If you include the following macros:
// PORT B<br>#define EnablePullDownB(bits) CNPUBCLR=bits; CNPDBSET=bits;<br>#define DisablePullDownB(bits) CNPDBCLR=bits;<br>#define EnablePullUpB(bits) CNPDBCLR=bits; CNPUBSET=bits;<br>#define DisablePullUpB(bits) CNPUBCLR=bits;<br>//PORT A<br>#define EnablePullDownA(bits) CNPUACLR=bits; CNPDASET=bits;<br>#define DisablePullDownA(bits) CNPDACLR=bits;<br>#define EnablePullUpA(bits) CNPDACLR=bits; CNPUASET=bits;<br>#define DisablePullUpA(bits) CNPUACLR=bits;
Then you can just write
EnablePullDownB( BIT_7 | BIT_8 | BIT_9);
ZIP of project
keypad
The physical connections for servral styles of keypad are shown below. You probably will want to use the
12-key models.
Connector:  top:8-pin      top:9-pin   bottom  12-key
Pin 1  ---- row 1 2 3 A    col 1       col 1    row 1 (pin A0)
Pin 2  ---- row 4 5 6 B    col 2       col 2    row 2 (pin A1)
Pin 3  ---- row 7 8 9 C    col 3       col 3    row 3 (pin A2)
Pin 4  ---- row * 0 # D    col 4       col 4    row 4 (pin A3)
Pin 5  ---- col 1 4 7 *    row 1       row 1    col 1 (pin B7)
Pin 6  ---- col 2 5 8 0    row 2       row 2    col 2 (pin B8)
Pin 7  ---- col 3 6 9 #    row 3       row 3    col 3 (pin B9)
Pin 8  ---- col A B C D    row 4       row 4    ----
Pin 9  ----              (NO CONNECT--common)
(a) Each switch shorts one row to one column. When in doubt, get the ohmmeter!
(b) On the 9-pin models, do not connect the common lead.
tft and keytft and key
For DDS lab:
  • TFT uses pins 4,5,6, 22 and 25 (RB0, RB1, RB2, MOSI1, SCLK1)
    SCK1: connected to RB14 on the PIC
    MOSI (SDO1): PPS output group 2 connected to RB11 on the PIC
    CS: connected to RB1 on the PIC
    SDCS: left unconnected as I'm not using the microSD card for this
    RST: connected to RB2 on the PIC
    D/C: connected to RB0 on the PIC
    VIN: connected to 3.3V supply
    GND: connected to gnd
  • DAC SPI channel 2 uses
    SCK2 pin 26
    SDO2 (MOSI) is in PPS output group 2, could be connected to RB5 which is pin 14, but remember to set #pragma config JTAGEN = OFF, DEBUG = OFF<br>CS (chip select) connected to RB4, pin 12, but remember to set #pragma config JTAGEN = OFF, DEBUG = OFF
  • Keypad -- need 7 i/o lines (see schematic above)
    A0 to A3 and B7 to B9
