Connections can be painful
A project log for SNES Controller Arduino Adapter
Interface with SNES controller using Adruino over Serial or USB.
zvoddzvodd 09/03/2015 at 04:450 Comments
As mentioned previously there were some issues with the plug, see the culprit:
The V+5 line was pushed out. Reattached and applied ample hot glue.
The makeshift adapter:
The working setup:
Successful output:
Edit : Link to source code SnesTest.ino
