Printed the dolly today, the threads needed some force the first time but now runs really smooth.
The entire project is now classified as a stepperdriven linear actuator opereated high voltage switch.
What is left now is the rest of the assembly, PCB and function definitions.
I want it to disconnect if the mains power go out. I want battery backup and a charging circuit.
And of course it will disconnect when sensing thunderstorms on the radio, stay disconnected for a set amount of time after last radio activity, same with powerloss.
I also want a couple of buttons to override. Maybe throw in a display to display timers and lightningcounts.
I want to cram all this into a Attiny 84 or something, use some MOSFETs to power my overpowered stepper motor.
