Thermal Jacket
A thermal jacket that checks the exterior temperature, and it heats up the wearer if the temperature has fallen a certain threshold.
As part of the hardware project for grade twelve computer engineering, my friend and I had decided to make a thermal jacket that is designed to keep the wearer comfortable when it gets too cold. The thermal jacket is uses an Arduino board, which is powered by batteries, that would check the outside temperature using a temperature sensor, and if it is too cold, it will activate the heating pads that would warm the wearer.
  • 1 × Arduino-Compatible R3 UNO ATmega16U2 AVR USB Board $9.59
  • 1 × 6 x AA Battery Case Storage Holder With DC2.1 Power Jack For Arduino $2.68
  • 6 × Heating Pad - 5x10cm $23.70
  • 1 × Temperature Sensor - TMP36 $1.50
  • 6 × MOSFET $18.98
View all 7 components
