ESP8266 1-Wire Temperature Controller
Uses the ESP-12 to create a WIFI-enabled, UDP-controlled 1-Wire controller using a DS18B20 Temperature Sensor and 2 DS2406+ Digital Switches
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
Using an ESP-12 or ESP-07, This board uses the ESP8266/Arduino IDE to monitor and control a DS18B20 Digital Temperature Sensor and two DS2406+ Digital Switches. A 20x4 HD44780 I2C-controlled LCD is also supported. The Board can be setup via the Serial Monitor to use either DHCP or a static IP for intranet communication. Control is via UDP, and a small set of PHP programs on a website. MySQL is used to log the temperature, and GNUPlot provides a graph function.
