How to place IC's perfectly without jiggly suction tools
A project log for Skoobot
Tiny robot for Hacking and EdTech.
bill-weilerBill Weiler 04/12/2018 at 06:580 Comments
Pro tip: Make a part placement suction device out of a syringe and a aquarium pump (reverse the valve). Put in a long tip, drill a pressure release hole and clamp it in a panavise. Adjust the height, tilt the panavise to pick up the part, and perfect placement! (disclaimer, I am not a pro).
